Not sure about a new sensor… I’ve only had it recently so that’s a good idea. Few leaks were given new gaskets and sealed. Will look more at the down pipe might have overlooked there. Thanks for replyWide pipe makes no differance . When’s the last time it had a lamba sensor ? Are all the exhaust joints good with no leaks around the downpipe and up pipe
Yes, I cleaned it out… minute bits of particles and majority oil like substance. Ali seems to think it might be ok with a clean. Took ngk spark plugs out cleaned from MAF sensor coked up and set them they were spaced at 1.00 to .70… does that seem accurate ? cleaned air intake valve on top of carb also coked. Amongst an extra cat changeDipetane is probably what Gary got, but lamda sensor could be the issue
My daughter will loose the plot if she ever sees I’ve posted this… to proud not to post it. It was a quick sketch for her art class
