allrighty lads..the radios came today....pheewwww and in time for japfest
after drivin around blanch like a thick for ages i got me hands on the cigarette lighter adaptors which unfortunitley didnt come with the radio.
so this evening i got 9 out of the 10 soldererd onto the leads and are ready to rock.
the japfest list goes as follows
sti brian
mick spec c
pete
turbo tony
sweetcakes c/o keith.
the radios simply plug into the cars cigarette lighter plug and the volume knob switches on the radio. you then collectivly select a channel choose either am or fm and talk away.
with regards to the antenna, the bootlid is ideal as the cable can be fed from the boot trough the back seats and under the front seats to the glove box . the whip of the antenna can be unscrewed from the base when not in use and put into the boot .
i have programmed each radio to the eu spec, i would advise in a convoy to pick a channel ie ch 10 and switch the radio to fm with the auto squelch on. the auto squelch is on when the squelch know is turned anti clockwise till you hear a click and the letter A appears on the display. the auto squelch will keep the static noise out while letting the voice audio trough. some members who have cbs allready might only have am, if this is the case all the radios will have to be switched to am if they are to join in the conversation. this is the reason why i got radios that can switch to both am and fm.
any questions or problems ring me........at any time ....
ps i would advise you put something like a piece if j cloth under the magmount, it has a rubber boot but just as a cautionary mesure
