[quote author=johnb4 link=topic=12980.msg162506#msg162506 date=1235844019]
[quote author=Altezza-Dan link=topic=12980.msg159425#msg159425 date=1235379370]
Lovely looking car John, great to see another new shape Legacy on board! Looking to do similar myself and there is a few different options, all depends on your budget, very unlikely to get much change from 10K if your looking for 350 whp. Engine internals would need doing, turbo swap, and a shed load more.
Im planning on either a turbo swap to a VF36 from an Impreza spec C or else going down the hybrid turbo option route. Any mods would need ECU remap. Im not sure how your ecu will like that Induction kit though. Car might run a bit rich/lean.
But as Dave Legacy said the bottle neck is the small Vf38. Great low end torque and spool up but lacking a bit more in the mid to high ranges. Has your been remapped yet or danything or is the induction kit your first mod? I hope your running it on E5 at least
i was actually looking at those vf36 myself.
yeah induction kit was first mod, is the powertec no good for the legacys.
no it hsnt been mapped yet .any info on what type of exhaust system would be best.or what mod would be next
its going for a dyno test in april so looking to get it up as much as possible,without spending a fortune as cant spend to much on it yet
as have to wait until the missus has the baby
vf36 would be the best setup for the Legacy's but expensive too, what i have found out so far is that you need to change the up-pipe, down-pipe, headers and have a larger diameter exhaust system from turbo back,uprate the fuel pump, and injectors and then a remap.
other option Davelegacy has mentioned is a hybrid VF38 which has VF36 internals, so less bits need to be changed
Not very many aftermarket exhaust systems available for Legacy. Zerosports de-cat Downpipes are going for 900 euro.
Cheapest option is to get customs system made up through one of our traders.Hayward and Scott in UK offered to custom make a system for mine at a good price since they never made a system for the BL5 Legacy, they could use it as a template then to sell onto other customers
De-cat from turbo back, uprated fuel pump and injectors and remap would see you to about 300-ish and you can build from there. but turbo choice should be your first concern as every other mod is dependent on which turbo you decide to go for. I might be able to get you in on a dyno session in march if you want
