Yes I have a picture, whats your email and ill send it to you.
I'm guessing it was a 60 mm drop from standard, it was generally fine for everyday driving but you would need to be careful of ramps and curbs when parking!
I was always under the impression that the wagon had different set up to the saloon . Deffo different top hats on the struts so dunno if the wagon springs are the same as saloon .If the top hats are different surely the spring will be specific to the saloon or wagon . That link also contradicts itself . I'd check for sure before buying anyway .
Thanks for the heads up tommy anyways, I will do more research about these and find out if they fit... I am still afraid that these 60mm are too much and they would not clear my 18'' wheels
I got your pm so ill send you the pics, the car has 18 inch 225 alloys in the picture with the lowering springs fitted. i didnt have any rubbing issues
ill send you a pic with the standard springs and the 15inch wheels on it too so u can compare
this is how my roo looks like with 18'' with standard set of springs. While yours is lowered, I dont think its 60mm, it looks to me more like 30-40mm. I am however very interested in your springs then, and I hope they will fit since Tommy said they might not, but I assume thats no longer of your problem
confidence went straight up, I am not sure if its placebo, but it feels like when I am accelerating, its slightly more agile due the fact that there is no bodyroll at all. Also no bodyroll in turns, which feels great as I can take sum turns even faster than before Still need to get used to a new brakes and get the alignment done, so I dont want to overstretch it yet too much, will see after a week or two... so far I like it.. but my missus havent been in since I installed them, so the verdict is still to come
How did you get rear wagon springs to fit the 4dr there's another member here that got a set of springs from a 4dr and said the rears wouldn't fit his wagon??
Could it be from 4dr to wagon dosent work but from wagon to 4dr does??
