GC8 Timing Belt Questions
Thanks guys for all your help. Keep any info coming as I am out of touch with these old machines.
You can mix up the connections easy enough as in mix up front and rear cylinders on both banks
Oh ok I must check that out if anc when I get it running again. I also want to change the spark plugs to a much higher quality plug when I get it all sorted.
Is there only one cam shaft sensor on the passenger side or is there one on the drivers side also?
So it’s a green maf you’re looking for .
The top of that is missing anyway so someone was messing with it .
would have 1 here but not local to swap in maybe someone closer .
Are you reading the codes from the check engine light blinking .
Long flash is 10
Short flash is 1
So it’s a green and you’re looking for .
The top of that is modding anyway so someone was messing with it .
Long flash is 10
Short flash is 1
Ha ha yes to all your answers. I don't mind driving today if your about ?
