hi lads the rubbers around door windows r leaking and d wind is grttin in and it is doing my head in is there any way of fixin it or would i have to replace
hi have you tried to adjusted your glass angel ?
most times its not the rubber even on the older models road vibration over time will loosen the screws
take off the door panel and try adjust the Phillips screws for the window
hope this helps
