Wheels for a Blobeye Wrx Wagon
The Quadcam
Hi All,
Will any of the newage saloon wrx or Sti wheels fit straight on to the Blob wrx wagon or are they different ?
Fit straight on as they're only a 7" wide wheel so will take a 215 tyre and look good on a wagon
Sent from my SM-G981B using Tapatalk
Straight on, as long as they from wrx /sti up to 05 or wrx any age need to be 5x100.
Sti 05 on was 5x114. [emoji106]
Hi All,
Guessing you're on 5x100 pcd?
If so, the stock Sti wheels will fit perfectly. I had them on my blob wagon before and they suit.
I run 5x100, 215/45/R17 tyres, Et 45 and 8J on my blob wagon.
The wagon has narrower rears and hence wider wheels with lower offsets will rub e.g I had a set of 5x100, Et35 and 8J wheels which rubbed on the rears. I had to roll my fenders to make it fit bit it was flush as after with the fenders. My car is on coils which helps a bit with adjustment.
Any pictures of the car? Not that many wagons on the forums and don't think I have seen your car [emoji4]
#hmblwgn
www.instagram.com/hhphoto7
Thanks for the advice and information lads ,
would like a set of revolution millenniums if I?m honest if they will fit ,
