Turbo timer removal - Dublin
Amjon36
Hi - I have a turbo timer that has been malfunctioning recently, stopping start up - beeping for a few minutes then allowing start up and also draining the battery. Where would you go to get the timer uninstalled completely?
Depends if it’s plugged in with a proper wiring harness I’d so then just unplug . Or some butcher could have spliced it in and cut loads of sh*t up and taped it all up . Have a look under your dash and see
