Is it coming from the front or back?
Ive an awful noise comin from the back passenger shock which i suspect is the top mount.
Common problem i believe.
had a similar problem before, thought it was the top mounts or the exhaust banging but turned out that some clown had refitted the rear windscreen and done a bogey job, was not secured at the bottom. Dunno if that helps
