tractorman
Squeeking noise from front wheel when going around corners? Any ideas?
Alan
Alan
mine was making a squeeking noise untill yesterday(sounds like a high pitch squeel),it was comming from the front drivers wheel. i took the wheel off and didn't find anything so then i took the disc and caliper off. i noticed on the inner brake pad that either side of it there is two small pieces of metal and with the pad worn down they were exposed to the caliper and rubbing off it,i think they are there to stop stones lodging themselves in the pad so all i did was bend them back enough to give enough clearance on the disc. only took about 20 min to do and sorted the squeel out!!!
