if you want to post a pic of the head of your key (but not the blade due to security reasons ) il see what i can do or point you in the right direction .
I need help guys. I'm looking for spare key with alarm fob . I rang Subaru dealer today ... 350eur (real bargain)
Any ideas where can I do it a little bit cheaper ??
thx...
More troubles lads. I left my key for replace old battery but one "nice" lady put battery upside down ( I saw it a few days later )
. Now my fob doesn't work at all. Have you any idea how can I reprogramming my fob ? ( Impreza 05 )
Finally I coded my new key fob so maybe it could be helpful for someone.
I have 05 Impreza
"Undo the plastic door sill protector (driver door with right hand drive model)
Undo the trianglish plastic plate at the front of the sill protector, right to your gas pedal just at the lower front corner of the doorframe
Hidden under the plate are two cable ends with plastic plugs, possibly clear/whitish. Connect (doesn’t matter whether the window is up or down, the door closed or shut, or the key in ignition or not)
Press “Lock” on the working remote, then immediately afterwards “Lock” on the new one. Then press “Open” with the working remote and straight afterwards “Open” with the new one"
Below is a picture showing where the plugs are located.
