keith555 Octane Boostaholics Jun 19, 2013 #1 Looking for a set of smoked or dark side repeaters for a blob eye if anyone knows we're to get hold of them. Cheers Keith.
OP OP keith555 Octane Boostaholics Jun 20, 2013 #4 Cheers lads. Scoobyworld are crazy money and scoobyparts have them but confused. Need to see a bugeye side repeater first to see if there the same.
R Rob Spec C Octane Boostaholics Jun 20, 2013 #5 They are all he same fitment in the wing but your 05 should be all one piece, you need to get a set which has the lens and then bulb holders as well. If you find lens' only, then you can get the bulb holders from a breaker bugeye or a B4 Scoobyparts give the bulb holders with them: http://scoobyparts.com/acatalog/LIGHT_SMOKE_REPEATERS.html or here: http://scoobyparts.com/acatalog/LIGHT_SMOKE_REPEATERS.html You can also get the cheap enough off ebay. The good thing is with the bulb holders you can then change to chrome bulbs
OP OP keith555 Octane Boostaholics Jun 20, 2013 #6 Ordered the bugeye ones from scoobyparts which are on sale. I have bulb holders there which need to to be wired to the existing wires but might go and get a set of a breaking bug eye instead like you mentioned rob.
R Rob Spec C Octane Boostaholics Jun 20, 2013 #7 Much easier to do that as the bulb holders are the same plug so it'd be much cleaner
OP OP keith555 Octane Boostaholics Jun 21, 2013 #9 [quote author=davelegacy™ link=topic=38280.msg438312#msg438312 date=1371767613] Loads there [/quote] Cheers dave i was going to give you a buzz today to see did you have any. will only need the bulb holders as I have ordered the repeaters.
