Thanks baz.Inlet manifold off , so 2 gaskets needed , once off you may need to separate the fuel pipes and loom to remove the old one ,
Tricky time consuming job especially the first time .
If you want I could give you a hand doing it some evening if it dry lol
If you or the weather is dryInlet manifold off , so 2 gaskets needed , once off you may need to separate the fuel pipes and loom to remove the old one ,
