RCM PARALLEL SIDE FEED FUEL RAILS WITH -6 fitting ..€100..
KENC
These are surplus to my requirments now, i cant pull a picture from the RCM website :wall: if i can i will take pics but i am having a problem with cable for camera. they look like standard rails, but have are parallel set up and have -6 outlet and inlet so will require fittings to suit, these are considerd to be one of the best upgrades you can do to your fuel system, and is a must at a certain point
There 146 GBP + shipping
Mine are used so wont be shinny :icon_cry:,
€100
Al and chris, they are from a v5/ v6, so as far as i know they will not fit either off your cars without adapters from CARL Davey, if someone knows for sure, feel free to post
They will fit older models if you are running newer type phase 2 injectors with adapter kit to phase 1 / 1.5, just get rid of the adapter kit and the injectors will bolt straight in. I don't think an adapter kit exists to convert phase 1 / 1.5 injectors to phase 2 rails, most people are going the other way.
as i said they need to be cleaned up, the blue fiitings are not included, you buy your own :thumbsup:
Yep there still available, so there yours then if you want them
there my number if you want to contact me
Re: RCM PARALLEL SIDE FEED FUEL RAILS WITH -6 fitting ..?100..
BUMP
