head gasket is gone or on its way out only did 1 there myself not so long ago for the neighbour was doin the same hot and cold air bleed it out only worked for a short period
it was low on water so opened up the rad bleed screw and bulkheader bleed screw.. filled through the header tank until the rad was full, closed the screw, filled again so that the heater matrix filled up... Then rechecked both and started the car... hot air straight away, no bother with and drove over 60miles since then... Not 1 issue with the needle rising up or down...
Sure look, if it does go then there'll be a punto for breaking cause i ain't spending any money on it
