tks Sheriff, ill give him a go.. is he based in Galway?I got mine sorted by Dave at RSR Automotive
RSR Automotive | Dublin
RSR Automotive. 2,710 likes. Online Auto Parts Company.Genuine,OEM and Performance Parts for all makes and Models.With a specialiwww.facebook.com
085 771 5343
might be worth a shot Enda.... where did you get the orings?you can get o-rings and rebuild it your self if your confident ? I did with mine , vids on youtube... I took mine apart and took out the orings, then got new ones.
the car is a 2007 wrxMake sure you prime the pump by hand before you put the Belt on an just turn it over and it’s running if not primed. Top up with fluid and turn the pully by hand and top it up . What year of car is it
I got them in North side dublin - https://www.hydraseals.ie/might be worth a shot Enda.... where did you get the orings?
tks Enda, ill give them a try.. cheersI got them in North side dublin - https://www.hydraseals.ie/
tks Baz.They give trouble around that year ,
as Joe said the key is priming it correctly, lift the reservoir above the pump inlet and use the belt around a battery drill and the pump pulley to rotate it and fresh Dextron III fluid only , all the best
