JAMIE-TYPERV6
Phase 2 thermal inlet manifold spacers
WHAT ARE THEY...
These are highly effective gaskets for preventing heat-soak from your engine's cylinder heads to the alloy inlet manifold, therefore lowering your air intake temperatures substantially and supplying cooler, denser air to your engine.
Cooler Denser Air = More Power.
If you've ever placed your hand on your inlet manifold after a hard drive you'll know how hot they get. Tests using 8mm thermal gaskets on Subaru engines have seen a substantial drop in intake temperature, with the main benefit being that they help to keep temperatures under control after prolonged engine use. So these are a proven & effective way of lowering your air intake charge.
These high performance, composite spacers are precision CNC cut from 8mm Tufnol Phenolic Resin, which has a maximum continuous working temperature resistance of 120 Degrees Celsius (248 Degrees Fahrenheit).
Included in the kit are 8 x Stainless Steel M8 Cap Bolts and Washers which will allow for the additional 8mm increase in height.
Important Note - I strongly advise fitting 2 new OEM Subaru metal gaskets on either side of the thermal spacer when fitting. These will allow you to run a higher than standard boost then just using gasket sealer. These can be gotten through Subaru (OEM Part # - 14035AA421) or from Import Car parts …
http://www.importcarparts.co.uk/par...96&sub=97&sec=142&var=74&dc=y&gen=&searchKey=
In Summary...
-Precision CNC cut High Performance Phenolic Resin.
-Helps supply cooler intake air. Cooler Denser Air = More Power.
-For every 5 Degree reduction in temperature, increases in power can be as much as 1%.
-Direct bolt-on fit to all EJ Engine Types - EJ20/22/257.
-European made.
-Phenolic Spacers are able to withstand 248 Degrees Fahrenheit. Subaru engines run at around 200 Degrees Fahrenheit... so Phenolic Spacers are well within a Subaru Boxer's Max. running temperature.
-Safe to run with Race Fuel, E85, E5 and Methanol.
-These Phenolic Spacers conduct substantially less heat than the OEM steel gaskets.
These are available as full kits for €65.00 posted nationwide. (Delivered by Registered/Insured mail).
ALL PRICES EX VAT.
PM me or post here if you are interested in a set. Or buy direct from my eBay shop..
http://www.ebay.co.uk/itm/151616063844
Regards,
Jamie.
PHASE 2 THERMAL INLET MANIFOLD PHENOLIC SPACERS
***DIRECT FIT FOR ALL SUBARU EJ ENGINE TYPES V5-6 ONWARDS - MY98 - 2012***
WHAT ARE THEY...
In Summary...
-European made.
ALL PRICES EX VAT.
Regards,
Jamie.
