Oil temp and/or Boost gauges
I have both and while the app is great for reading codes it's slower and not as accurate as the gauges boost is a good bit off
Handy tool to have but you can't beat a good gauge for keeping an eye on your pride and joy
I've only lamco boost gauge find they both read exact same.
so, I bought one of those bluetooth obds, and that bloody thing doesnt work, cant connect it with phone at all... so, I'd rather go for something more reliable...
When it comes to gauges, cheap (as per first post) and reliable don't usually go hand out in hand.
I really cant see point in fitting cheap in accurate gauges.
As if not accurate then your guessing anyway and may as well have none.
If your just after the look then a cheap set will do . But as above buy a proper set defi,s or something similar :thumbsup:
