Hi Hammie,
Not entirely sure on that one, I never had an issue with oil pressure when I fitted one but I also never had a gauge to check it ( excluding the one in the dash ) so couldn't tell you if it went down or not? The one in the dash would indicate if it was too low though so I would say it was fine.
I can tell you that I did have to replace an oil pressue sensor in my car a few months after I fitted it, I doubt it was related as I replaced the sensor and I never saw the light again.
I'd say its like sticking on a front mounted intercooler, extra length makes some difference initially but once up to pressure, makes little to none
If you are concerned, you can get a gauge from thinkauto that connects onto the oil cooler...
