Altezza-Dan
Failed on emissions, i dont think there is anything wrong with the car mechanically wise, maybe something small like exhaust or gasket leak, but i dont think it would cause this. Gave it a good drive on the way to the center to get it nice on hot but failed on high idle emissions:
Oil temp: 82c
Low idle(760rpm)
CO 0.02 vol%
HC 13 ppm
High idle(2850 rpm)
Lambda 1.02
CO 0.51 vol% and it need to be below .2%
HC 47 ppm
He said he gave it an extra few mins to get hot but thats the lowest it got.
Car is a twinscroll legacy with vf36 and sports cat cell just before the cat back system. Passed fine with this cat last time in 2012. I need to connect up my laptop and check the AFR values etc. Also got an Innovate wideband AFR gauge today so ill fit that and see what the AFR is like. Hopefully its something simple, rather than a knackered cat or sensor as they are all less than 2 years old
Oil temp: 82c
Low idle(760rpm)
CO 0.02 vol%
HC 13 ppm
High idle(2850 rpm)
Lambda 1.02
HC 47 ppm
