my first play with cad software to design a replacement shock turret for the ka these will be welded in place of the original shock turrets. to in conjunction with mazda rx-7 camber mounts allow caster adjustment and camber adjustment on the front struts ,my plan is to be able to achieve -1 degrees to -8 degrees caster and -6 degrees to -1 degrees camber .sounds great in theory doesn't it
