legacy b4 power problem
can meet over in Spawell tomorrow, anyone else thats around is welcome to pop over for a chat! will be there at 2pm :subaru:
Hi lads, just got the call from sti tuning today.................. problem found.
The exhaust housing on the turbo is cracked!! :angry1:
[quote author=Altezza-Dan link=topic=23346.msg279998#msg279998 date=1273265473]
cheers 4 the help today lads, was nice meetin yaz :subaru:
no probs :thumbsup: is the engine check light still on? must find someone on here with OBD2 fault code to see what its throwing up. Full service recommended s soon as possible!
[quote author=Altezza-Dan link=topic=23346.msg280233#msg280233 date=1273361150]
yea lights still on, ringing the number yaz gave tommorow and seeing what can be done, cheers dan :beerbang:
driving much better though for the time being at least :subaru:
Hi dan, rang ciaran, waiting on him to phone me back, i wonder could you send me a photo of the bar/bracket and bolt missing from my intercooler that is on yours please? you said there are two bl5s for breaking in the country at the moment did ya?? cheers man :xmas_cheers:
Is the part number the last one on the list below? :ponder2:
EDM:
Subaru of England:
JDM Parts: Can be ordered from: (2004+ model in Japan)
http://www.japanparts.com
http://www.avoturboworld.com
EDM Parts: Can be ordered from: (2004+ model in UK)
http://www.cheammotors.co.uk/content.php?categoryId=37
Random part numbers:
J2010AG001## - Armrest Extension with Additional Storage – Black
C8110SA020 – pedals install kit
E721SAG000XX Spoiler,
E3610AS190 Kayak Carrier Kit
E3610AS890 Ski/Kayak/Roof Bskt. Mtg. Clamps (Round Cross Bars)
E3610AS181 Cross Bar Set, Round
E3610AS940 Bike Attachment (Hitch Mounted)
E3610AS790 Ski Attachment, 6 pair Kit
E3610AS820 Ski Attachment Mtg. Clamps (Flat Cross Bars)
E3610AS802 Bike Attachment 1
E3610AS810 Bike/Kayak/Roof Bskt. Mtg. Clamps (Flat Cross Bars)
E361SSA100 Fork-Mounted Bike Carrier 2
E3610LS430 Front Wheel Holder
F541SAG000 Moonroof Air Deflector
F551SAG500 Compartment Separator/Dog Guard w/Moonroof
F551SAG000 Cargo Net, Rear
F551SAG100 Cargo Net, Rear Side Compartment (2) each
F551SAG200 Cargo Net, Rear Seat Back 3
H711SAG000 Security System Upgrade (Perimeter Alarm)
J501SAG050JD Rear Cargo Tray, Off Black
J501SAG050WB Rear Cargo Tray, Ivory
J2010AG000JD Center Armrest Extension, Off Black
L101SAG000 Trailer Hitch
SOA787V100 Cooler/Warmer
SOA303N100 Cargo Area Spotlight
SOA868V9500 Severe Weather Companion
H630SAG000 Subwoofer/Amplifier
E231SAG000 Hood Protector (Non-Turbo?)
E231SAG200 Hood Protector (Turbo?)
SOA342L305 Front Bumper Guard
E7710AS105 Bumper Corner Molding-Rear (2 pair)
J501SAG000 Floor Mats, All Weather
T3010YS010 Wheel Locks (Alloy Wheels)
C8110SA000 Metal Pedal Pad Set M/T - STI
C8110SA010 Metal Pedal Pad Set A/T - STI
E1010AG010 Side Sill Plate – STI
36024FA010 WRX Pedals Pad Clutch Brake Pedal
36024FA000 WRX Pedals Pad Accel Pedal
909130051 popits
H501SAG100 home link mirror
66060AG07A OEM Navigation bezel
E361SAG300 Extended Roof Cargo Carrier
010110200 h-brace bolts (the ones you remove in order to swap the front swaybar)
56410AG06A – Under tray for the GT
95011AG61AJC – SpecB dead pedal
28111AG090 - Spec-B 18" Wheel
28821SA040 - Subaru Logo Wheel Center Cap
28811AC110 – Subaru center wheel cap
83002AG490 - The illumination control "roller"
800910340 - Uppipe studs
14459AA460 - intercooler to throttle tube
34311AG23AJC – SpecB Steering Wheel
83153AG000 - Satellite controls fro steering wheel
E2610AG000## - Rocker Panel Trim
800410020 – Flywheel screws - 8 Required
34311AG13AJC - Black Leather Momo steering wheel 2005 LGT (no controls)
86201AG61A - Complete stereo and dual zone climate control assembly
85021AG49A - Instrument panel
85201AG020 – Clock
14025AA22A – Stock engine cover
84912AG271 - EDM rear wagon fog lamp
84963AG000 - EDM rear wagon fog lamp resistor
83002AG070 - Outback w/VDC switch with VDC button
30100AA810 - Clutch Disc
30210AA550- Pressure Plate
30502AA120 - Throw -Out Bearing
12345AA010- Flywheel
91121AG12A – Stock grill
031432000 – Snap ring for shifter rod
35035KA010 – bushing for shifter rod
85021AG51A - Instrument Cluster - Metric in km/h - 05 Legacy GT MT Canadian model
85207AG111 - Clock/Trip meter - Metric - Displays temperature in Celsius and L/100km for gas mileage
901000252 Is the bolt at the top of the Cusco brace
901000110 Is the bolt at the bottom of the Cusco brace
902350006 is the nut for that bolt.
14459AA340 Turbo inlet
93073AG560 - Spec B Emblem:
15194AA110 - Banjo Bolt for the turbo (Called a union screw by SOA)
803910050 – Washer for 15194AA110 (Called a gasket by SOA):
14459AA60 - Duct assembly (IC to throttle body tube)
16272AA001 - TVG to block gaskets
22310AC270 - Hose Ay-vac cont (The part highlighted in the picture above)
14471aa130 – stock BOV
803926070 - manual transmission oil drain washer/gasket
26300AG000/26300AG001 – Front rotor
26700AE080 – rear rotor
93073AG560 - Spec B Lettermark includes "Legacy & Spec B"
93073AG160 - Subaru letermark –
010108300 - Bolt used to attach intercooler (3 total...2 to turbo, 1 to brace)
[quote author=Altezza-Dan link=topic=23346.msg280714#msg280714 date=1273576878]
yep thats the one, couldnt see that part listed though, should be able to get it from Subaru dealer
cheers lads thats a big help thanks :xmas_cheers:. Btw dan i rang the number yaz gave me and yer mans phone rang out, i left a msg and he never rang back. Im only back in Dublin now,was away for a few days ill give him a buzz again in a few minutes and if he doesnt answer or call back ill find someone else on here.
this might be of interest to you dan got these emails from souhan exhausts, ill copy n paste whats relevant:
1. Magnaflow direct fit Cat-Back system (part # 16747) would cost you €640.00 fitted inc VAT.2. Magnaflow Cat-Back system using Magnaflow components would cost you €490.00 fitted inc VAT.
2. We do De-Cat pipes & Sports Cats (high performance Magnaflow Cat), the cost of the High Performance Cat would cost you €240.00 fitted.
