As scoobysub said, engine is running fine, even the wheel tries to turn when I put a bit of throttle(had to while I was pushing the car into garage), so I assume and hope that the power rod with differentials and steering rod will be OK. I really wish they are.
Other than that, currently I ordered Whiteline drop links for both sides and have on order with Dave the Wishbone and Tie rods, he said it should be there by monday, so this weekend I will go to garage and strip everything off and try to fix the bent fenders and perhaps kit it and spray it.
As soon as I have them parts I will start putting it on. Problem is that the drop links are ordered from US, and while they are dispatched, there is big questionmark when will these arrive. Another problem is, that I ordered new ROTA wheel, but probably missclicked and instead of front polished gunmetal gray I ordered only Gunmetal Gray. Well I wanted to paint them dark anyways, so it seems I will have to that now...
Edit: Guys, the more into technical, would you be able to see from the pictures, if the Anti Roll bar got damaged as well or is it looking ok? As far as I am aware, anti roll bars are 'spongie' so they have certain percentage of bending that they return to the original shape, unless the force is too big. Am I right on this one?
Also, if its damaged, I will be probably looking at 'upgrade' instead of getting the same part. What effect would uprated front antiroll bar have for the handling of the car?
