as above lads in need of a set of inner shafts for a 04 wrx box they are leaking a small bit if anyone knows where there is one being broke all help much appreciated
did you check the size of the inner shaft mateing face to the size of the inner diameter of the seal in the box. just read the other thread, afaik they are a different part number so even thou the shaft fits. it may not seal correct
