Headlight Restoration
[quote author=Rob Spec C link=topic=37842.msg433784#msg433784 date=1367609527]
As long as you have a machine Tom, you'd be all year trying to do it by hand :nono:
Did you get a DA from cleancar? Best with a rotary, but give the DA a go and if it doesn't work, you can borrow my rotary :thumbsup:
Ross, Do they need to be sanded again or just polished up?
Yeah i have the DA from clean car , its slow work with it but with some patience it gets the job done , cheers for the offer of your rotary man , will try elbow grease and the DA first though , be afraid of over doing it with the rotary :yellowthumb:
robbie there pretty bad and need a good going over .
its just not top of "the list" atm .
will be in touch
This is from when we done Eli's car, one pass on the rotary with a finishing pads and polish :smile:
Before
After
just gave mine a rub the other day by hand with 3m compound and pad, not bad took the bad look of them, but they were not to bad to start with so prob why i got away just doing by hand, bit of hd wax over them then,
