R Roche Member Feb 24, 2024 #1 Well lads my impreza failed on emissions has anyone a cat for one thanks
Eoinmack Webmasters Staff member ISDC Club Member Feb 24, 2024 #2 Hard found now man tbh. Stick up a pic of the fail sheet. Some lads might know if it's sensor or cat related
scoobysub Well-known member ISDC Club Member Feb 26, 2024 #4 Do you have a standard cat in the car at moment . Looks like you lamba is well out . When was the lamba changed last
OP OP R Roche Member Feb 27, 2024 #5 I got a loan of a cat with a lambda in it i probably should a swapped over my own lambda
scoobysub Well-known member ISDC Club Member Feb 27, 2024 #6 Yes as it’s way out out or else there’s a huge leak swap your own lamba over if it’s a known good 1
subiescooby Matthew ISDC Club Member Feb 27, 2024 #7 HC passed so looking like the cat is fine. 0.91 lambda means its running rich which would make the CO fail along with it, so looking like the sensor alright
sc86 Well-known member Mar 5, 2024 #11 Do i get a free pint? Roche said: Changed my old sensor in and she flew thanks lads Click to expand...
