Front Windscreen Washer Pump Issue
Cahal Hawkeye
2006 Subaru Impreza wrx sti Hawkeye
Any ideas on where to buy a windscreen washer pump for the front handy online?
Issue with the front windscreen washers and was advised to replace the pump as it is faulty. The back windscreen washer is working.
Any advice appreciated, thanks
Hi Cahal,
Presume motor is gone? If so ebay probably your best bet or breakers
If not done worth checking hoses not kinked or split and removing bottle and giving it a good wash out as sometimes get gunked up..also a pin into the washer nosles on bonnet can sometimes work freeing em up too
Thanks Ciaran eBay or that hadn't even crossed my mind.
Tried all the above and no water going to the front at all, just the back which was strange. Swapped the wiring around and it does seem to be issue with the motor then. Would be typical with nct up Friday 😂
