If you want I could repair that for you RobJust putting out a feeler in case I need front right brembo, pulled the threads where banjo bolt goes in. Any condition doesn't matter, let me know what's out there and thanks in advance
Rob ,I don’t think anyone will split a pair of front calipers in fairness, so just be prepared to buy a pairStill need front right brembo any condition lads if any around cheers
TomorrowTomorrow in Wexford had a set
No threads pulled on banjo bolt and tried a helicoil but that pulled on tighten up tooWhat's up with the caliper Rob is it the bleed nipples
