F
forester sti
Guest
Newage has a stronger motor than the classics, But they are no indistructable,
Fenster, you may expect a melted piston at some stage I'd imagen!
As above, Your new down pipe has freed up the turbo a lot, so much so that the turbo spools so much faster that she over boosts then fuel cuts then over boostes then fuel cuts again! Over boosting would mean that she is pumping more air in and the fueling can't keep up, so she runs lean, which means it runs much hotter and hence a melted piston!
Mapping will take advantage of the freer exhaust and she'll be a flyer!
Davelegacy (STI Tuning) is mapping this weekend the 8th, my car will be there!
Nic spec c will give him a good referance! And me,
0857715343
Dan
0857715343
Dan
