Hey All. I'm getting the above fault code so i'm looking to see if anyone has the oxygen sensor matching this code. From putting it in the part number i need is 22690AB010. Partsouq is out of stock but priced at 113 Dollars. If anyone could advise that would be great or even if anyone has one spare lying around i could check that this is in fact the cause of my engine light issue coming on and off. Dave in Carrol and Roche was kind enough one day to come out and plug in(when the engine light happened to be off) and was able to get live readings and all appeared normal and readings as he was expecting.
