emissions
crafen95
Active member
had my sti in for a test during the week and failed emissions. very like a lamba sensor do people think? car has the oem cat and standard exhaust system on.
Have a fuel pressure regulator on it but have it set at 3 bar without vacuum which is normal fuel pressure for them. oem ecu and doesn’t burn any oil engine is new. lamba is only reason I can think of why it failed.
there are impossible to get new for the ealy v1 and v2 models , if you find a source let me know.
Very common to go
AP used a Bosch one from a Turbo 2000 on my car for finish up. You have change around the wires on it, not sure in what order as wasn't there when he done it.
Ye lamba way off where it should be . Have used a few Bosch universal sensors when genuine ones can’t be got . Not straight forward as in plug and play but not that bad either 👍
