Dave in Rsr automotive usually has a fewLooking for 3 electric window motors for a 2000 Impreza. Anyone know where I could get these? Thanks
Thanks. Il give him a tryDave in Rsr automotive usually has a few
No it’s notIs the window lock button on ?
Great. What’s the best way to contact you?I've all 4 - can post to you.
Ya the passenger and 2 rear. Sometimes the window will drop slowly bit by bit and take ages to get it to go upUnusual to have 3 motors fail . Make sure you check the switches . Are they the passenger window and 2 rears . If so remove the single switch’s and spray with some electrical contact cleaner and see then as had it happen before nothing would work From the driver door
Give me a call 087 2740527Great. What’s the best way to contact you?
