Re: Re: DIY Oil Change Reqired
[quote author=seanie link=topic=37704.msg1#msg1 date=1366446763]
As above. I unplug the coil and crank til light goes out. Saves rooting for fuses. Also always remove oil cap first, golden rule never drain anything you can't refill.
On classics only need to unplug the cam sensor.
On new age will still start with cam unplugged
And handier to pull fuse then unplug crank sensor on them
