geogan
Have an 03 STi Type UK. So the car was fine until Saturday when I turned the key and... nothing... just the sound of starter - no ignition. I drove over 100 miles a few days ago with no problem.
There is power, I can hear fuel pump priming up as normal when key is initially turned, and when started, the starter is turning the belt and main crank.
I have tested the crank sensor with multi-meter and it has resistance in normal range (i think) and I also tested starting without crank sensor in place and no difference.
I took out battery to make sure it wasn't that and left it charge overnight to full charge (its new battery only a few months old) but no difference next day.
I took out all four coil-packs to examine, but apparently from what I read from expert source (as opposed to some idiot youtube videos I found) it is not possible to check resistance on a 3-pin coil-pack, so no way to tell if they are good or bad.
I haven't removed or checked spark-plugs yet, but I can't imagine all four would go together, and one bad would not stop a car from starting. They are also quality Denso I put in as far as I remember.
I tried to buy a "spark tester" but doesn't seem to be any available to buy in Ireland (in stock), have to try and locate one online. Anyone know a good one that works with boxer engine layout? Is the light ones good enough or should I try the fancier "spark quality" screw type ones?
I also checked for any engine faults using OBDII reader connected to phone, and none, and no "check engine" light either.
Anyone know any other areas/parts related to ignition I might check?
I have heard that corrosion in power lines may drop voltage too low on coli pack to let it work. Can I test this somehow with multi-meter?
