Hi sti 9029,
is dagnut right about the gogo juice?also someone on here told me they can take 1.3 bar boost with the standard fuel pump,does that sound right?
No that is not correct You would definitly need to fit an Uprated fuel pump !!! Will the car take 1.3bar boost without one, Yes
but for how long
Sti 9029, The amount of options who have is endless. There has been 100's of post's on this very subject .
So use the search option and do some research.
Is Dagnut right: probably / maybe ???? it's very hard to say most would agree that the Maxol 99 Ron , is not all
what it's cracked up to be.
My Advice until you get her mapped fit a "Knock Link" should cost about 150. This will detect any pre-det due to our shitty
fuel and warn you to slow down. You now could try some Maxol E5 and see dose the car run better and detect less knock(pre-det).
If you just want a re-map for fuel only ..................get the cheapest ECU and go with that. Yes you will get more BHP/Torque.
If you are looking for some higher BHP figures then you need to look at Turbo's, Exhaust's , Fuel regulator's, FMIC etc.........
If you go down this route then the Apexi , Simtek etc........ ECU's are bets suited for this level of mapping.
Simtek can also provide Anti-lag and launch controll but it cost's a bit more.
Look at Our Traders Section and see what some of the traders are offering , these lads will have all the info you need
Niall.
