Rob Spec C
[quote author=FRAWLS link=topic=5399.msg61510#msg61510 date=1202753542]
Fitting a downpipe alone doesn't require a remap but if you're looking for anything over 260 bhp then you will have to get a remap so you might as well get the fully exhaust system and panel filter. For 280+ on your classic turbo you will need to change your turbo for something the same size but more efficient (TD 04H) or something bigger (td 05 16g, 18g or 20g) and map it for e5 (or e5 plus Octane booster for a bit more bhp & torque).
A far as your original question goes the above options are going to cost you at least 3k fitted and mapped so you might consider the following package which wont break the bank
1. Fit a K&N Panel filter
2. Fit a Dawes device
3. Fit a second hand full exhaust system
4. Run her on Maxol E5
The above 4 simple and cheap mods should give you a quick car running 1.1 bar reliably with about 250 bhp
Frawls
This might be a schoolboy question but what is a dawes device?
Frawls
