[quote author=forester sti link=topic=23426.msg280006#msg280006 date=1273266984]
Hi,
In typical subaru "lego" form,
Everything shold just bolt on!
It would be a great time to flush new fluid into the system! well worth doing!
Although it's not absolutely nessisery,
Best of luck man!
Dan
cheers dan, when you say flush new fluid in is it as simples as draining the old through the lines when i take off the calipers and then toping it up or is it more complicated. i want to try and do it all myself as the rest justs bolts on. ill never learn if i let someone else at it.
