Nope no lights whatsoever. Yeah tried voltmeter on it and battery is perfect checked all fuses and all ok. Have immobilized on car was on it when I got the car tried that also
double check that its + to + and - to- cause there should be something on lad try the parker switch on top of the steering colum . theres no power going anywhere so it has to be battery related . why did you change the battery
With your multimeter check where the positive goes into the fuse box and the chassis (top shock mounting bolt ideal) then altenator to chassis then starter to chassis,If its a new batt you should have over 12volts at each point.
[quote author=wrx99 link=topic=34464.msg396313#msg396313 date=1338328224]
Did you get a chance to post it?
[/quote]Dave's phone number is in the bottom of his posts mate.Best off ringing or texting him.
