car not idling properly with a blitz bov
i had an sti with that green thing broke on it, fixed it and made no difference either, sounds like your drawing air some where, is cacum pipe gamaged somewhere? and for some odd reason, you didnt t it off pressure reg did you?? sounds like drawing air on tick over causig eratic idling do... check for way for air to get in
oh yea, is that mounted direct to ic, if so is gasket alrite? basically anywhere uv been at that can draw air check :thumbsup:
[quote author=KENC link=topic=12884.msg159310#msg159310 date=1235344820]
i checked the vacuum pipe and its fine and i didnt t it off the reg :thumbsup:
[quote author=KENC link=topic=12884.msg159314#msg159314 date=1235344968]
it mounts to the pipe coming from the intercooler, i think v5 bolt to the intercooler direct
[quote author=555-Scooby link=topic=12884.msg159303#msg159303 date=1235344177]
Not being a smart a##e but is it a genuine Blitz dump valve??? lots of fake ones around.
i bought it off http://www.japperformanceparts.co.uk/part_list.asp?search=&Make=Subaru&Category=Induction
:thumbsup:
[quote author=555-Scooby link=topic=12884.msg159709#msg159709 date=1235410663]
open it up and check the spring, the one in my mates blitz broke into two....
i opened it up today and its fine, i got it going properly there was a slight leak in the pipe going to the inlet manifold the car is idling properly now :thumbsup:
would these boost readings be right since i fitted it ,2nd gear .9bar, 3rd gear 1.3bar, 4th gear 1.1bar, 5th gear 0.9 at 100kms
