Can anyone recommend a supplier for the rear subframe bushings on my classic Impreza? I havent priced the main dealer yet but I imagine they will be expensive!
80 Euro each? I guess that isnt too bad - I'll go with the Subaru stuff so. These are the bushings that sit just behind the sill - one on the left & one on the right, yeah?
Were they hard to fit, does the whole beam need to come out?
I figured as much. I had to do the same job lately on my E30 Beemer. Awkward ole job, wishbones, diff, brake lines, halfshafts all had to be taken off. Im hoping the Impreza will be less work!
EDIT: Where did you source the bits for your Legacy?
i have hks coilovers and combined with the bushings the car is quite hard. if you are only replacing the subframe bushes the car should feel fine, the powerflex bushes are handy to fit once the old bushes are removed.
