In Detail
submitted by Richard Owen
price $ $ 30 000 GBP
engine Turbocharged Flat-4
position Front
aspiration Turbocharged
valvetrain DOHC, 4 Valves per Cyl w/AVCS Variable Valve Timing
fuel feed Electronic Injection
displacement 2457 cc / 149.9 in³
bore 99.5 mm / 3.92 in
stroke 79 mm / 3.11 in
compression 8.2:1
power 238.6 kw / 320 bhp @ 5800 rpm
specific output 130.24 bhp per litre
bhp/weight 216.22 bhp per tonne
torque 420 nm / 309.8 ft lbs @ 4000 rpm
redline 7000
body / frame Unit Steel w/Aluminum Hood
driven wheels 4WD w/Driver Controlled Center Differential, SureTrac Front LSD,
front tires 225/45R17 Bridgestone Potenza RE070
rear tires 225/45R17 Bridgestone Potenza RE070
front brakes Brembro Vented Discs w/4-Piston Calipers, EBD, ABS
f brake size x 323 mm / x 12.7 in
rear brakes Brembro Vented Discs w/2-Piston Calipers, EBD, ABS
r brake size x 312 mm / x 12.3 in
front wheels F 43.2 x 19.0 cm / 17.0 x 7.5 in
rear wheels R 43.2 x 19.0 cm / 17 x 7.5 in
steering Rack & Pinion w/Variable Assist
f suspension MacPherson Struts w/Lower L-Arms, Coil Springs, Tube Shocks, 20mm Anti-Roll Bar
r suspension MacPherson Struts w/Lower L-Arms, Coil Springs, Tube Shocks, 20mm Anti-Roll Bar
curb weight 1480 kg / 3263 lbs
wheelbase 2540 mm / 100 in
front track 1491 mm / 58.7 in
rear track 1486 mm / 58.5 in
length 4415 mm / 173.8 in
width 1740 mm / 68.5 in
height 1405 mm / 55.3 in
transmission 6-Speed Manual
gear ratios 3.636:1, 2.375:1, 1.761:1, 1.346:1, 0.971:1, 0.756:1, :1
final drive 3.90:1
top speed ~249.4 kph / 155.0 mph
0 - 60 mph ~4.25 seconds
0 - 100 mph ~10.67 seconds
0 - 1/4 mile ~12.8 seconds
Supercar Spotlight
Read more at
http://www.supercars.net/cars/2931.html#tHPvOWkwaybqmwwk.99
