[quote author=Altezza-Dan link=topic=25657.msg302331#msg302331 date=1281394855]
do the BE5 legacys have OBD2 port under the steering wheel? I have the cable that can connect that up to me laptop and you can check and error codes stored in ecu, if ur bulb is broken but its still throwing codes. it might help
Ive seen a Black connector plug, female, just below the level to open the engine bonnet. Under the steering column.
I would appreciate it if you could read the codes for me with your pc!
Im going to try and get the clocks off now , and see if I can find the broken bulb.
Sweetcakes, it's not a picture of mine. I just found a similar pic on google.
Thanks guys.
Thanks guys.
