Has anyone ever had a problem with the battery draining constantly? After about 10 days mine always seems to be dead
Brand new battery, alternator has been checked with no issues. Could it be a tracker?How old is the battery?
press the remote fob`s button with the ignition on, then press 3 on the keypad and immediately remove the keys.
This will put the car into "valet mode" if that helps ?
Basically shuts off auto-arm and passive immobiliser..
Hope that is what your after mate ?
I've had the car 3 years now, it has been a problem since I got it. I'd usually disconnect the battery when I'm not using it but I think it's about time I got it sorted. I have a receipt from a garage to say a new tracker was fitted in it in 2017 but doesn't say the brand or anythingWhen did the problem start and had anything being done/ fitted to the car around that time
Yes if batteries aren't moving quick stock wise so a battery could be sat on shelf for a while but never not be enough to start the car and then it will be charged in car so all goodWhat alarm is on it
The sigma alarms can kill it in a few days like clifords
Happened me but giving the battery a full charge with a battery charger solved it
Is it possible to get a new battery that isnt fully charged due to sitting around not sure ?
