R rossieod Sunday Drivers Feb 6, 2019 #1 Hi I disconnected the electric seat on driverside before and the airbag light never came on before so I broke the seat and I have to take it out to fix it got it fix but airbag light came on what can I do to get it removed?
Sheriff Octane Boostaholics Feb 6, 2019 #2 You can?t just get rid of it with a computer. Check the connections are all in tight and are not snagged on something. Plug them out and in again.
scoobysub Well-known member ISDC Club Member Feb 6, 2019 #3 Check the connection and it should go off itself after the ignition is turned back on or as above Clear the code and see does it come back
dontommy Well-known member ISDC Club Member Feb 7, 2019 #5 I thought most airbag lights need computer to get wiped, mine did anyway after I changed the steering wheel
Sheriff Octane Boostaholics Feb 7, 2019 #6 I couldnt wipe my light but I disconnected the battery, made cables were tight and it was gone.
