Re: Re: Aftermarket boost controllers
[quote author=BazGF8 link=topic=40910.msg1#msg1 date=1393226066]
[quote author=davelegacy™ link=topic=40910.msg1#msg1 date=1393204400]
[quote author=BazGF8 link=topic=40910.msg1#msg1 date=1393202910]
[quote author=davelegacy™ link=topic=40910.msg1#msg1 date=1393202589]
[quote author=BazGF8 link=topic=40910.msg1#msg1 date=1393202043]
[quote author=davelegacy™ link=topic=40910.msg1#msg1 date=1393201674]
[quote author=Keadeen link=topic=40910.msg1#msg1 date=1393200631]
As the lads said: try with a mechanical gauge to verify.
Also though it is a known issue with non mechanical gauges to be bit sensitive and there are easy ways to fix this without spending a lot.
Ciaran WRX had a post about a week ago with a similar thing with needle "vibrating". Proper fix is get a restrictor pill in the hose going to the sender, but a cheaper fix is to use 1 or 2 cable ties hand tighten them on the fed line... Drive and see how it reacts. If needle is still very fast to climb and fall and still bit twitchy, tighten ties a little more to restrict hose diameter going to sender. Want to basically restrict it to smooth the flow to the sender.
Worth a shot as quick and cheap to try
so use cable ties mid vaccum pipe??
I'm guessing it acts as a restrictor pill
a restrictor pill is used for boost control.
boost gauge is manifold pressure.
using cable tie mid vaccum line would give inaccurate gauge readings.
if have inaccurate gauge readings then may as well have no gauge.
I know that.
What I meant is to slow the movement of air in the pipe so the map sensor for the gauge still reads the same pressure but smoother if you get me .
surely would agree slowing movements mid line through the increments of a cable tie is total wrong advice for accuracy???? and anyone reading should ignore?????
giving essays as answers does not any which way make any answer better or advisable
Not an essay at all Dave.take me about 10 seconds to say it.
And the Nissan I have has a restrictor pill just before the map sensor for the factory electronic gauge ( all factory ) so I assume its there for that reason?not saying the same for a Subaru.
I can see where your coming from and you know I respect your opinion but can you not see where we are coming from?
Also wouldnt be into the cable ties on the pipe
yes i do
a lot of gauges of a reducer/pill fitting on them.
top my head hks it used to be on the t-piece supplied with kit and racetech i think was on back of gauge.
my point is that the cable tie is not the correct way of doing it. and certainly not because a few people on forums say it if you do a quick search.
