Altezza-Dan
So do many of you have any sort of AFR gauge in your scoobys? i was thinking of getting one or two gauges installed in the car to help monitor things. AFR being one of them and oil temp being the other mounted in a steering column pod so i dont have to stick them on the dash. My current digital boost gauge mounted in the airvent can be "upgraded" to add a sensor for oil pressure so i think with the boost, AFR, volt, oil temp/oil pressure and knock detector thats all the main areas covered that are useful to monitor. Is there any other ones i should be considering?
