H harrry Sunday Drivers Nov 22, 2011 #1 Have a 99 classic was missing got code 22 changed knock sensor still missing wont rev past 4000 and erratic idling sometimes stalling no fault code any ideas
Mad Paddy RS Octane Boostaholics Nov 22, 2011 #2 have you tried clearing the fault to see if it comes up as code 22 again
OP OP H harrry Sunday Drivers Nov 22, 2011 #3 Had battery disconected for 2 days would that not reset the ecu
scoobycolm . ISDC Club Member Nov 22, 2011 #4 is it the right knock sennsor they vary and is it torqued right
OP OP H harrry Sunday Drivers Nov 22, 2011 #5 Got one off another classic looks same torqued ok would it still be gone if no code shows up
R Rob Spec C Octane Boostaholics Nov 22, 2011 #6 If you've erratic idle, then you may also have a maf problem? Check for a code 23 also.. The car is protecting itself by not revving above 4,000
