2004 impreza heater control bulbs
eliroche
Where would i get the bulb/holders that go into the back of the heater controls? Or what even are they called so i can find online!
Could be Subaru part no. 72350FE010.
Which I Think are the green cap ones,
Lamps are T6.5 AFAIK.
From memory you can replace the green or red shroud if they are present.
Could be worth trying a local Toyota dealer as look very similar and most would have larger stock inventory if you get me.
Them bulbs pull out Eli so if you have the holders just the get the bulbs in the motor factors if missing the holders too then they can’t be that expensive new or a breaker
If they are a 286 capless bulb they can be got in any motor factors very common dash bulb
Thanks lads, they pull out alright! I didnt notice the long connection so that had me puzzled but i broke that..! Little green cap on them also, will get one in motor factors and replace bulb in holder.
