doggy
When changing the rear pads today, I noticed that there was significantly more wear on the outer pad on the left rear compared to the inner pad. The inner pad was also more difficult to remove. Caliper pistons both moved freely enough. I cleaned out a lot of material around the caliper where the pads would slide in and out to help the new pads. What could be causing this, is it possible to have a single piston sieze and if so, how do you diagnose it? Is a full caliper stripdown the only way to get to the bottom of it?
Thanks in advance
Thanks in advance
