Tgv deletes info anyone?
Ciaran WRX
I see this mentioned around from time to time anyone on here with a wrx done this?
Is it the butterfly valves inside the manafold of the wrx that aren't there in the sti red manafold ?
Red somewhere the tgv helps with cold start emissions is there any advantage for me to do this?
With my set up
Vf35
3inch pipe work
Sti pinks
Sti top mount
Sti uppipe
& sports cat
Cheers for any info lads
Thanks Colm @ Dave Is there any advantage to having the tgv delete ? Would it need a map tweek after u recon?
Also Would there be a advantage to fitting the red manafold if it's already in it (apart from the look).. :dontknow:
Hi.
No advantage fitting red manifold bar looks. So that be deciding factor.
Yes advantage fitting tgv deletes. They are prone to sticking.
Be no power increase over what you have tbh. But if ever had manifold off be good time to do it.
Yes 110% needs be mapped afterwards also to turn off cel codes
[quote author=davelegacy™ link=topic=42334.msg484963#msg484963 date=1406558615]
Airflow
i think most jap models have them as standard, well mind did :) I sold a set a few months ago
Have a look at a pic of one with and one without
It looks like a big restriction having them in
Was going to do this mod to mine but it has it done from Subaru
I did on mine. Fairly simple job. Mine was starting give trouble. Mapped after.
As Dave said no need to replace all manifold it's only lower part of it.
[quote author=Federal link=topic=42334.msg484976#msg484976 date=1406575436]
What was happening when it was giving trouble?
Why is it on the wrx and not the sti?
Sounds like the same silliness as the wrx having a pre cat in the uppipe and the Sti having a straight pipe..
[quote author=SCOOBYCOLM link=topic=42334.msg484982#msg484982 date=1406580076]
Because Sti s are real cars for real men :hjtwofinger:
You better get down the credit union so and trade off that "wine " wrx & stop messing about with that boys impreza :sold
Didn't feel anything wrong. Just engine light came up as my tgv stuck open. So wasn't notice any other side effects.
[quote author=Ciaran WRX link=topic=42334.msg484984#msg484984 date=1406580282]
Its maroon :icon_biggrin:
